does anybody know how to display rosversion in dude of all connected mikrotik devices?
Thank you for answer.
Andrej
Andrej
Look for appropriate oid and put it to device appearance field.
That is not exactly what I need to see. I have a lot of APs, and I have a lot of clients. There is Wireless Registration table in Devices->RouterOS->Wireless Registration and there I want to see a column with ROS Version. Or is there any other view to achieve that?
Unfortunatelly I guess not. But there is “neighbor” tab just nearby that shows it.
Hmm that is not what I am looking for. In wireless registration tab you see all of the connected clients of all aps. What you wrote is only for certain AP if I open it.
No, If you switch on discovery on all interfaces, ros devices will inspect their neighborhood and will report what they have found. By this you can see versions of all devices around.
