How to solve the problem with DHCP
I have set time control for the child. Everything works great. Unfortunately, the option to use random macaddress changes frequently in the phone.
How to solve the problem that if it is an unknown device, it should not be assigned an IP address.
I have devices in the network that I cannot enter a static IP for, so STATIC-only is out of the question.
Can I make some kind of mac-address list that DHCP will assign IP to?
model router RB760iGS
Thank you for your help
Piotrek
You could try ..
  • for all your known devices, convert their leases to static using one part of your subnet, say from x.x.x.50 up
  • Shrink the DHCP scope to only issue addresses from a small range, say from .16 to .30 Choose something that can easily be expressed as a prefix, in that example it would be x.x.x.16/27
  • Block those IP addresses from accessing the Internet at all
Or if you have control of the device, switch off MAC privacy for your SSID
It should also be possible with a RADIUS server (or User Manager for that matter):
It is also possible to hand out leases for DHCP clients using the RADIUS server; the supported parameters for a RADIUS server are as follows:
Access-Request:
  • NAS-Identifier - router identity
  • NAS-IP-Address - IP address of the router itself
  • NAS-Port - unique session ID
  • NAS-Port-Type - Ethernet
  • Calling-Station-Id - client identifier (active-client-id)
  • Framed-IP-Address - IP address of the client (active-address)
  • Called-Station-Id - the name of DHCP server
  • User-Name - MAC address of the client (active-mac-address)
  • Password - " "
