There is a point to point link with SXT AC on both ends. Distance is around 1200 meters and height at both end is 65 ft. Link was running fine for around 350 days (real uptime). But from last 10 days I'm totally frustrated with the link condition. No changes are made to the P2P link after first commissioning.
There is huge ping loss from AP to CPE frequently. In AP Log it shows - disconnected , too many pole timeouts. In CPE it shows - lost connection, extensive data loss. Also another strange thing observed was that during first link commissioning, the difference between Chain 0 & Chain 1 signal level was 3/4 db but now I noticed its exactly 10/10 db. Like C0 = 59/59 and C1 = 69/69.
I have done the following changes at AP end to check if problem resolves but no luck-
Changed frequency
Changed protocol from nv2 to nstreme. (Only good was decrease in latency)
Changed channel width from 20/40 to only 20. (B/W requirement is just 25-30 mbps)
Rebooted device at both end.
What other changes shall I do to make the link stable? Attaching device config for both ends.
AP
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac disabled=no frequency=5200 hw-retries=8 mode=bridge wireless-protocol=nstreme
set [ find default-name=ether1 ] mac-address=4C:5E:0C:F1:4E:85 name=ether1-local
/interface wireless nstreme
set wlan1 enable-nstreme=yes
/interface vlan
add interface=bridge1 name=MGMT vlan-id=99
add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=SHARK supplicant-identity="" wpa-pre-shared-key=xxxx \
wpa2-pre-shared-key=xxxx
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add address-pool=default-dhcp interface=ether1-local name=default
add bridge=bridge1 interface=ether1-local
add bridge=bridge1 interface=wlan1
/interface wireless access-list
add comment=P2P disabled=yes mac-address=4C:5E:0C:F0:B4:35 vlan-mode=no-tag
add address=192.168.168.20/24 comment=MGMT-ACCESS interface=MGMT network=192.168.168.0
add address=192.168.80.1/24 comment=DIRECT-ACCESS interface=ether1-local network=192.168.80.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid interface=bridge1
add address=192.168.88.0/24 comment="default configuration" dns-server=192.168.88.1 gateway=192.168.88.1 netmask=24
set servers=4.2.2.2,8.8.8.8
/ip dns static
add address=192.168.168.20 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established,related
# no interface
add action=drop chain=input comment="default configuration" in-interface=*2
add chain=forward comment="default configuration" connection-state=established,related
add action=drop chain=forward comment="default configuration" connection-state=invalid
# no interface
add action=drop chain=forward comment="default configuration" connection-nat-state=!dstnat connection-state=new in-interface=*2
add action=masquerade chain=srcnat comment="default configuration" disabled=yes out-interface=*2
add distance=1 gateway=192.168.168.1
/snmp
set contact="AP" enabled=yes location="NOC" trap-version=2
/system clock
set time-zone-autodetect=no time-zone-name=Asia/Kolkata
/system identity
set name=SHARK-AP
/system logging
set 0 action=disk
add disabled=yes topics=wireless,debug
/system ntp client
set enabled=yes primary-ntp=123.108.200.124 secondary-ntp=194.225.50.25
/system routerboard settings
set cpu-frequency=720MHz
/tool mac-server
add interface=ether1-local
/tool mac-server mac-winbox
CPE
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=20/40mhz-Ce disabled=no mode=station-bridge name=wlan2 ssid=SHARK-ABTS-AC-AP
set [ find default-name=ether1 ] mac-address=4C:5E:0C:F0:B4:34
set wlan2 enable-nstreme=yes
/interface vlan
add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=SHARK supplicant-identity="" wpa-pre-shared-key=xxxxx \
wpa2-pre-shared-key=sb5xxxx
add bridge=bridge1 interface=wlan2
add address=192.168.168.19/24 comment=MGMT-ACCESS interface=MGMT network=192.168.168.0
add address=192.168.80.2/24 comment=DIRECT-ACCESS interface=ether1 network=192.168.80.0
/ip dhcp-client
add dhcp-options=hostname,clientid interface=bridge1
set servers=8.8.8.8,4.2.2.2
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www port=8000
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/snmp
set contact="CPE" enabled=yes location="NOC" trap-version=2
/system clock
/system identity
set name=SHARK-CPE
/system ntp client
set enabled=yes primary-ntp=123.108.200.124 secondary-ntp=211.233.84.186
/tool sniffer
set filter-interface=ether1 filter-stream=yes streaming-enabled=yes streaming-server=192.168.168.11
Registration table - Imgur: The magic of the Internet
AP Error Messages - Imgur: The magic of the Internet
Thanks,
Srijit B
