How to specify NAS ip when using radius with multiple IP's
Is there any way to specify which IP the radius client uses in the event of more than one IP being present on the interface? I have a problem that my mikrotik NAS is sending the wrong one to the radius server when two are present?
And another weird thing after removing the local IP to eliminate this problem above, the radius logs still show that the MT AP is sending it’s old local IP when users are logging in so radcheck will not work? I have NOT rebooted unit after removing IP but I did disable the Hotspot and Radius client and then re enable them. Should I reboot the router? I don’t like doing that as it’s holding up over 100 customers service, might try late at night?
Is this too advanced for people here to help me?
