I have simple access routing config where remote office LAN is routed via transit network to core.
Access to services (e.g. DNS, NTP) from the transit network is not allowed.
I should use local NTP and DNS servers for the local lan hosts, but now RouterOS NTP client uses the" Ether 1 gateway" = transit network IP when trying to access the ntp in the core, but this is blocked by the forewalls.
How do I specify that the router would use the local lan interface address (Ether 2 loacal ..) as source/host when accessing the NTP or DNS?
