How to surveille wireless clients on 40 Routers in same network
Hi forum,
I’m relatively new to the Router OS. So I’m asking here if anybody could give me advice:
In a network with 40 Mikrotik Routers (6.18) working all in Bridge Mode (there is an DHCP server for the whole network) I’d like to check with a tool or anything which IP&MAC is connected/resgistered with each router.
As -for example- you log in to the router, you will see under “Quck Set” the access list with IP, MAC and dB. Or you check with “Wireless/Registration” the clients.
And all I’m looking for is a tool to check this on all my 40 routers at the same time. I heard about a programm called “dude”, but I got no idea how to deal with that.
Maybe anyone has an idea or a tool or has to cope with similar things ?
Thanks for every help
You can use dude or you can implement capsman for (and not only for) that.
