Hi.
I’m now setting up rb493 to switch at one site of ours. But I can’t figure out how to make a simple switch out of it.
I don’t wanna bridge all ports.
help?
Regard
Lasse
Hi.
help?
Regard
Lasse
pick one as a master port, and specify master-port for every other interface.
How do I deside witch interface gets the masterport?
Pick whatever you like best ![]()
hihi;) Yes that I understand;)
But where do I set the parameter “masterport”?
See this example: http://wiki.mikrotik.com/wiki/Switch_Chip_Features#Port_Switching
Thanks to everyone who really try to help, but if I was suppose to use ether1 as master-port and all the other ethernets was going to use ether1 as master. What would the programmingline be?
Only ether2-ether9 can be switched together on RB493. To use ether2 as master-port for all ports use the following command:
/interface ethernet set ether3,ether4,ether5,ether6,ether7,ether8,ether9 master-port=ether2
Thanks a million!
Sorry for my lack of MT experience. But still learning.
Lasse
Norway
Hi.
RB750
Is i possible to switch all the five ports on this routerboard? As inn ethernet 1 master and ether2,3,4,5 slave?
Lasse
Only ether2-ether5 can be switched together on RB750.
thx again!
If the masterport on a routerboard is being disabled do I lose contact with all the other ports who has that port set av master? (if U now what I meen)
Lasse
Yes, all ports in that group couldnt communicate if you disconnect or disable master port.
