I have two Mikrotik CCR1009-8G-1S-1S+ devices. I configured one of them. I’m using several vlans, vpn connections, I have about 20 firewall rules. Now I need add second Mikrotik to this configuration and set up VRRP. I know that Mikrotik doesn’t sync configuration between devices. But maybe you can give me some advice what is the best strategy to keep config synced? I think even if I try to make the same changes on both devices - at some day there will be something what I will forget and devices won’t have the same config. Maybe there is some solution for that problem?
