How to tell if SFP+ DAC is compatible?
Just received an CSS326-24G-2S+RM switch and plugged in a 10Gtek SFP+ Intel-compatible cable. How do I know if this cable is compatible with the Mikrotik box?
FWIW, the “Link” tab shows the DAC with “link on” connected at 10G full-duplex. Also, the “SFP” tab has the first 6 fields filled out for this cable. Does this mean it’s good?
Thanks!
