I want transfer some files from my MT(ROS 3.3) to my another MT(ROS 2.9.38), or if possible, get file from myMT(ROS 3.3) to MT(ROS 2.9.38), plus put this in schedule so this script will automatic run every 2 day, pls help me
, thxs for read my post.
use the Fetch tool. you will need to make a new user on MT1 that has FTP access rights. Then on MT2 run the Fetch tool to get the file. You can make a script that repeats this.
Thxs for your info, my problem is, the file that i want transfer is on MT1(ROS 3.3), and I want transfer this file to my MT2(ROS 2.9.38, it doesânt have Fetch tool), why I do this, cause in my country (indonesia), we have local internet exchange (IIX or openIXP), everyday i was download file (local IP Address list, indonesia) for my ROS, using Fetch tool (/tool fetch address=ixp.mikrotik.co.id path=download/nice.rsc) and update my âniceâ address-list (import nice.rsc), my problem I canât update my another MT (MT2 ROS 2.9.38), cause this MT ROS, doesnât have Fetch Tool, please, if possible send me some command that i cant use to upload this nice.rsc file from MT1 to MT2. thxs Normis ![]()
you can use fetch tool, or do it manually. I donât think there is another way to do it. You will have to upgrade.
ok. I will try di upgrade my MT to Ver 3. thxs a lot Normis. GBU ![]()
Itâs possible to upgrade RB133 to 3.7 ?, I have RB133 & RB532 (use same ROS ver.2.9.38), did mikrotik have link to download ROS for previous version, like 2.9.50 ?, thxs ![]()
of course it is possible to upgrade a RB100. download 3.7 for RB100 and upload to your router. then reboot.
Ok. Thxs Normis ![]()
