How to transfer settings from v2.8 to v2.9
It’s possible?
upgrade should retain your settings, but I’ve yet to do it. Make a backup before you do anything :slight_smile:
Yeah it’s kinda possible. If the hardware is not exactly the same you will get some problems with the ethernet card allocation in my experience IE they will change position etc.
