How to transparently forward traffic?
Here is what I’m trying to achieve:
I have two Access Points, one at my Office, one at my Home.
I have a RB433 with two Atheros 2.4ghz wireless radios installed in it, both work properly.
What I need to do, is to seamlessly connect my Office LAN to my Home LAN without routing.
I want all traffic to be passed through just like a network switch would handle it.
My Office LAN is where the Router and Internet gateway will be located, there will be no router or gateway at my Home.
The two Access Points are not made by Mikrotik, but both support WDS.
I’m having difficulty understanding how I should configure this system, if someone could give me an example of how to configure my Router Board, I’d greatly appreciate it.
I’ve been trying to work this problem in my spare time, unfortunately I can not figure it out.
something like this?
http://www.mikrotik.com/testdocs/ros/3.0/vpn/eoip_content.php#.3.1
Yes actually that’s what I was looking for, thank you.
I’ll attempt to configure this when I get the time, I’ll post back if I successfully get it working.
