rusoo7
June 26, 2015, 2:23pm
1
I’m getting an interface warning “ethernet2: bridge port received packet with own address as source address, probably loop”. Does any know how to trouble shoot this? I cant find any relative information about this on the net. I’m using RB2011UiAS-2HnD. It appears to be happening exactly 60 seconds apart. Ethernet2 is master port for Eth3,4,5. It is Slave to my lan Bridge. Bridge is also mapped to Eth6 and WLAN. ETH2 seems to have Role of root port. I’m not sure if this is correct. Thanks in advance.
rusoo7
June 26, 2015, 2:49pm
3
Hope its not too must script to go through:
# jun/26/2015 18:14:09 by RouterOS 6.29.1
# software id = K9L3-THMQ
add arp=proxy-arp name=LAN/BRIDGE
set [ find default-name=ether2 ] name=LAN/ETH2
set [ find default-name=ether3 ] arp=proxy-arp master-port=LAN/ETH2 name=\
LAN/ETH3
set [ find default-name=ether4 ] arp=proxy-arp master-port=LAN/ETH2 name=\
LAN/ETH4
set [ find default-name=ether5 ] arp=proxy-arp master-port=LAN/ETH2 name=\
LAN/ETH5
set [ find default-name=ether6 ] name=LAN/ETH6
set [ find default-name=ether7 ] arp=proxy-arp master-port=LAN/ETH6 name=\
LAN/ETH7
set [ find default-name=ether8 ] arp=proxy-arp master-port=LAN/ETH6 name=\
LAN/ETH8
set [ find default-name=ether9 ] arp=proxy-arp master-port=LAN/ETH6 name=\
LAN/ETH9
set [ find default-name=ether10 ] arp=proxy-arp master-port=LAN/ETH6 name=\
LAN/ETH10
set [ find default-name=sfp1 ] name=NONE/SFP
set [ find default-name=ether1 ] name=WAN/ETH1
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" \
mode=dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk eap-methods="" group-ciphers=\
tkip,aes-ccm mode=dynamic-keys name=WIFI/SECURITY supplicant-identity="" \
unicast-ciphers=tkip,aes-ccm
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=\
20/40mhz-ht-above country=bulgaria disabled=no frequency=auto l2mtu=2290 \
mode=ap-bridge name=WIFI/WLAN security-profile=WIFI/SECURITY ssid=\
Brolin-WIFI wireless-protocol=802.11
add name=dhcp ranges=192.168.168.30-192.168.168.254
add address-pool=dhcp disabled=no interface=LAN/BRIDGE name=DHCP/SERVER
/port
set 0 name=serial0
/ppp profile
set [ find name=default ] name=default
set [ find name=default-encryption ] name=default-encryption
add bridge=LAN/BRIDGE interface=LAN/ETH2
add bridge=LAN/BRIDGE interface=LAN/ETH6
add bridge=LAN/BRIDGE interface=WIFI/WLAN
add address=192.168.168.1/24 comment=LAN interface=LAN/BRIDGE network=\
192.168.168.0
add address=96.86.191.125/28 interface=WAN/ETH1 network=96.86.191.112
add address=96.86.191.124/28 interface=WAN/ETH1 network=96.86.191.112
add address=96.86.191.116/28 interface=WAN/ETH1 network=96.86.191.112
add address=96.86.191.119/28 interface=WAN/ETH1 network=96.86.191.112
add address=96.86.191.121/28 interface=WAN/ETH1 network=96.86.191.112
add address=96.86.191.122/28 interface=WAN/ETH1 network=96.86.191.112
add address=96.86.191.123/28 interface=WAN/ETH1 network=96.86.191.112
add address=96.86.191.120/28 interface=WAN/ETH1 network=96.86.191.112
add address=96.86.191.115/28 comment="One-To-One NETMAP" interface=WAN/ETH1 \
add address=96.86.191.114/28 comment="DHCP Preffered" interface=WAN/ETH1 \
add address=96.86.191.117/28 interface=WAN/ETH1 network=96.86.191.112
add address=96.86.191.118/28 interface=WAN/ETH1 network=96.86.191.112
add address=96.86.191.126/28 interface=WAN/ETH1 network=96.86.191.112
add address=192.168.168.0/24 dns-server=95.87.194.4,95.87.255.194 gateway=\
192.168.168.1 netmask=24
set allow-remote-requests=yes servers=95.87.194.4,95.87.255.194
add action=drop chain=input comment="Disallow weird packets" \
connection-state=invalid
add chain=input comment="Allow LAN access to the router itself" \
connection-state=new in-interface=LAN/BRIDGE
add chain=input comment=" ^^ that originated from LAN" connection-state=\
established
related
add chain=input comment="Allow ping ICMP from anywhere" protocol=icmp
add chain=input comment="Allow Winbox" dst-address=96.86.191.114 dst-port=\
8291 in-interface=WAN/ETH1 protocol=tcp
add chain=input comment="Allow Ports to WEBSERVER" dst-address=96.86.191.115 \
dst-port=80,443,3389 in-interface=WAN/ETH1 protocol=tcp
add chain=input comment="Allow Ports to DEVSERVER" dst-address=96.86.191.120 \
dst-port=3306,3389,8443 in-interface=WAN/ETH1 protocol=tcp
add chain=input comment="Allow Ports to SVETLOZAR-PC" dst-address=\
96.86.191.118 dst-port=80,443,3389,8080,8443 in-interface=WAN/ETH1 \
protocol=tcp
add chain=input comment="Allow Ports to CHORO-LP" dst-address=96.86.191.123 \
"Disallow anything from anywhere on any interface"
add action=drop chain=forward comment="Disallow weird packets" \
connection-state=invalid disabled=yes
add chain=forward comment="Allow LAN access to move through the router" \
connection-state=new disabled=yes in-interface=LAN/BRIDGE
add chain=forward comment=" ^^ that originated from LAN" connection-state=\
established disabled=yes
related disabled=yes
"Disallow anything from anywhere on any interface" disabled=yes
add action=dst-nat chain=dstnat comment="One-To-One NETMAP" dst-address=\
96.86.191.115 dst-port=80,443,3389 in-interface=WAN/ETH1 protocol=tcp \
to-addresses=192.168.168.15
add action=dst-nat chain=dstnat dst-address=96.86.191.116 in-interface=\
WAN/ETH1 to-addresses=192.168.168.16
add action=dst-nat chain=dstnat dst-address=96.86.191.117 in-interface=\
WAN/ETH1 to-addresses=192.168.168.17
add action=dst-nat chain=dstnat dst-address=96.86.191.118 dst-port=\
80,443,3389,8080,8443 in-interface=WAN/ETH1 protocol=tcp to-addresses=\
192.168.168.18
add action=dst-nat chain=dstnat dst-address=96.86.191.119 in-interface=\
WAN/ETH1 to-addresses=192.168.168.19
add action=dst-nat chain=dstnat dst-address=96.86.191.120 dst-port=\
3306,3389,8443 in-interface=WAN/ETH1 protocol=tcp to-addresses=\
192.168.168.20
add action=dst-nat chain=dstnat dst-address=96.86.191.121 in-interface=\
WAN/ETH1 to-addresses=192.168.168.21
add action=dst-nat chain=dstnat dst-address=96.86.191.122 in-interface=\
WAN/ETH1 to-addresses=192.168.168.22
add action=dst-nat chain=dstnat dst-address=96.86.191.123 dst-port=\
80,443,3389 in-interface=WAN/ETH1 protocol=tcp to-addresses=\
192.168.168.23
add action=dst-nat chain=dstnat dst-address=96.86.191.124 in-interface=\
WAN/ETH1 to-addresses=192.168.168.24
add action=dst-nat chain=dstnat dst-address=96.86.191.125 in-interface=\
WAN/ETH1 to-addresses=192.168.168.25
add action=dst-nat chain=dstnat dst-address=96.86.191.126 in-interface=\
WAN/ETH1 to-addresses=192.168.168.26
add action=src-nat chain=srcnat src-address=192.168.168.15 to-addresses=\
96.86.191.115
add action=src-nat chain=srcnat src-address=192.168.168.16 to-addresses=\
96.86.191.116
add action=src-nat chain=srcnat src-address=192.168.168.17 to-addresses=\
96.86.191.117
add action=src-nat chain=srcnat src-address=192.168.168.18 to-addresses=\
96.86.191.118
add action=src-nat chain=srcnat src-address=192.168.168.19 to-addresses=\
96.86.191.119
add action=src-nat chain=srcnat src-address=192.168.168.20 to-addresses=\
96.86.191.120
add action=src-nat chain=srcnat src-address=192.168.168.21 to-addresses=\
96.86.191.121
add action=src-nat chain=srcnat src-address=192.168.168.22 to-addresses=\
96.86.191.122
add action=src-nat chain=srcnat src-address=192.168.168.23 to-addresses=\
96.86.191.123
add action=src-nat chain=srcnat src-address=192.168.168.24 to-addresses=\
96.86.191.124
add action=src-nat chain=srcnat src-address=192.168.168.25 to-addresses=\
96.86.191.125
add action=src-nat chain=srcnat src-address=192.168.168.26 to-addresses=\
96.86.191.126
add action=masquerade chain=srcnat comment="Default Masquerade Rule for LAN" \
out-interface=WAN/ETH1 src-address=192.168.168.2-192.168.168.255
add action=dst-nat chain=dstnat comment="Redirect Ports to WEBSERVER" \
dst-address=96.86.191.115 dst-address-type=local dst-port=80,443,3389 \
protocol=tcp to-addresses=192.168.168.15
add action=dst-nat chain=dstnat comment="Redirect Ports to DEVSERVER" \
dst-address=96.86.191.120 dst-address-type=local dst-port=3306,3389,8443 \
protocol=tcp to-addresses=192.168.168.20
add action=dst-nat chain=dstnat comment="Redirect Ports to SVETLOZAR-PC" \
dst-address=96.86.191.118 dst-address-type=local dst-port=\
80,443,3389,8080,8443 protocol=tcp to-addresses=192.168.168.18
add action=dst-nat chain=dstnat comment="Redirect Ports to CHORO-LP" \
dst-address=96.86.191.123 dst-address-type=local dst-port=80,443,3389 \
protocol=tcp to-addresses=192.168.168.23
add action=masquerade chain=srcnat comment=\
"Masquerade Traffic going to WAN IP of mikrotik from local LAN users" \
dst-port=80,443,3306,3389,8080,8443 out-interface=LAN/BRIDGE protocol=tcp \
src-address=192.168.168.0/24
add distance=1 gateway=96.86.191.113
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/lcd
set enabled=no
/system clock
set time-zone-name=Europe/Sofia
/system identity
set name=Brolin-FW
/tool romon port
add disabled=no
rusoo7
June 29, 2015, 9:48am
4
Just to add that there is also nothing physically connected to the Eithernet2 port
as far as i can see Eth2 is master port, so any port that have eth2 as master is eth2, from software point of view. So packet can arrive to any of those ports.
Usually when you receive packet, it indicates that problem is elsewhere in your network - some kind of loop, so check your network structure.
Also Proxy-arp looks kinda strange there - why do you use it everywhere?
rusoo7
June 29, 2015, 10:36am
6
When i was having issues with the router i sent it in for checkup and configuration. They set it to proxy-arp. When i saw it i wondered about it but wasn’t sure what it’s for and so i left it as is.
I change it to “enabled” and the network wasn’t effected in any way.
The Warning is still there
rusoo7
June 29, 2015, 12:44pm
7
Thank you Macgaiver,
I did what you said, i reviewed the entire network by unplugging the cables one by one to narrowing down where the loop is coming from. I narrowed it down to another Mikrotik that is configured to work like a switch. It had “Admin. MAC Address:” for the Bridge set to same address as the interface where i was getting the warning. I removed the address and the warning is gone.
Do you know if it normal for the bridge to have the same mac address as one of the Ethernet ports? It seem to have inherited the mac address from Ethernet 4.
Maybe someone exported the config with the bridge and mac admin address set and imported it the other router.
rusoo7
June 30, 2015, 8:01am
9
This is exactly what happen, i learned my lesson to do export instead of loading backup file from another router.
m4rk0
August 7, 2015, 7:20am
10
Is there any other way to detect duplicate mac address?
My case is that interface spoiled, disable it then problem solved.
Sent from my Che2-L11 using Tapatalk
m4rk0
August 7, 2015, 10:18am
12
angboontiong:
Changed ether port, disabled other two, same error…
Do you bridge all the port? or,
Do you master and slave all the port?
unlink the spoiled port (refer to the log which port given problem), then you problem should solve.
