Hello ,
I want to find a suitable protocol to connect directly the brown router with the red router because i use radiusmanager and each router must have it’s unique ip.
IP Tunnel for general purposes
IPSec for a secure tunnel
EOIP Tunnel for bridging your network and carrying Layer 2 traffic
witch of these three methods is the correct to use? please be more specific
in what situation ?
Look ,
My RB2011 is my main router with local ip 192.168.88.1/22.
I want to connect the red router with the main brown router but the red router is connected via pppoe to the middle router!!! Please help me! ![]()
If you can ping last router so you can use ip/ip tunnel,if not you should setup up router’s routing tables in order to get ping
