While I type commands in MT terminal it plays smart and guesses what I want to type in. Usually that is quite useful, but as I am used to type in whole commands it just annoys me.
So I like to be able to turn it off.
There is actually more serious reason to turn it off.
While writing scripts, as MT’s script engine is very poor, and especially unfriendly for debugging, I get used to write script outside of MT and then copy and paste code to terminal to run it and at least get information if MT complies with errors.
In MT 3.x, as terminal plays smart, copy and paste code does not work any more as it is messed up with MT’s guesses what I actually wanted to type in. So if I paste…
/queue
… i actualy get…
/queue export ue
… and similar trash shows up in wholepasted code.
So there should be an option to turn of command quessing and force MT to accept characters as typed.
Alternatively, when you just go to the root page (http://router.ip.goes.here/) there will be a link to download winbox from the router in the upper left hand portion of the page.
