I cant get working vlan between l3 switch and mikrotik. For examle i’ve got tagget vlan id 100(ip 10.0.0.1/30) from switch, and i created vlan interface on the ethernet interface which connected to switch. vlan id 100 (ip 10.0.0.2/30). So i cant ping 10.0.0.1. What i do wrong?
If you properly set trunk connection from switch to MT it should work. What switch is it?
edge-core 4612
config is: vlan 100(10.0.0.1/24) from dlink 3526—> port9 (edge-core 4612( only vlan 1) port10–>mikrotik vlan 100 (10.0.0.2/24)
if i create vlan interface 100 with 10.0.0.3/24 on Egle-Core, i can ping 10.0.0.1 but cant ping 10.0.0.2.
you need to add vlan100 to 4612 with port9&10 tagged
find mistake… was checked “use service tag”
