hi every one
i have the routerboard RB532 . I want to upgrade its old software ver5.2
I can not upgrade it such as RB433 .
what is the wrong?!!
anyone have an idea ?
thank you to all
hi every one
thank you to all
Suport for MIPSLE architecture was dropped 2 years ago.
What's new in 6.34 (2016-Jan-29 10:25):
*) mipsle - architecture support dropped (last fully supported version 6.32.x);
I am running 6.32.4 on couple of my old 532A boards. You can download old version from the archive: https://mikrotik.com/download/archive
thank you
but how you upgrade your rb532 ? which steps you did to upgrading??
I can not upgrad it by copying and paste the soft package files to the files list with reboot the devise !!!
I was a long time ago, but one thing I remember is I bricked the device by installing newer version than supported. That’s how I found out about this EoL situation.
Since you can not use auto-update feature, you have to manually upload software packet to your RB532.
I did that way ..but the routerboard still with its old software ( no upgrading )
Alright, try couple of steps then.
First go for version 5.26
Then 6.27
Then the one linked previously.
If you can not install 5.26 this way, then I’m guessing you will have to learn how to use Netinstall application (another way of installing MikroTik software). ![]()
1- the first step = failed
2- the second step ( installing by using netinstall = failed
I am guessing you are trying to use the same package files that you have upgraded RB4xx with to upgrade your RB532. You can’t do that. RB532 has a different CPU architecture than RB4xx, so you need to download the appropriate package file for that CPU architecture, not just re-use the same one you already downloaded for your RB433.
The MikroTik download page clearly spells out what file needs to be downloaded for which RB model.
If you are sure that you have the mipsLe package for your 532, and aren’t trying to use the mipsBe package that you used for the 433, then after reboot, check the system log and it will tell you why it failed to update.
– Nathan
you are right
but what is the difference between / mipsle package and mipsbe package ?
thank you very much
mipsle is the name of the architecture, or the name of the CPU family
you can only use packages that are made for the specific CPU. mipsle is for your device.
thank you very much Mr.normis
im happy to see you replay
