How to use 2 Wan load bal/ppc over 1 lan
Hi all
First of all, sorry for my bad english.
And i really apreciate if someone can help me, i stuck over a week with this.
Can figure out how to configure.
I have one Mikrotik rb2011
Over eth1 i have ISP with 60mbps Range ip 10.0.1.0 gateway 10.0.1.2
Over eth2 the other isp 20 mbps
Range 192.168.1.0 Gateway 192.168.1.1
Over eth3 its connect to the switch, lan clients.
Can someone make a script to for PPC or load balancing. Over eth3 with dhcp server
Thanks in advance
How do you want to load balance??
three main methods
Round Robin - means taking turns for next session by the two WAN
Least Load - router assesses load and pushed next session to least loaded interface (not sure if hex looks at up down or both)?
Fail-over (not really load balance but simply use WAN2 only if WAN1 is not available).
Round Robin can also be weighted, so as to even out the load balance based on throughput capacity.
For example you have a 60:20 capacity difference 3:1 so to speak.
So it would be best to have 3 sessions go to WAN1 and then the next session go to WAN2 for example.
So asking for load balancing needs more clarification.
What kind of approach is required?
