Hi, i have a network of over 300 dhcp clients and i want to use 3 routers with one dhcp each. Clients should get an ip from one router , but be able to talk to the other clients that have acquired ip from an other dhcp. No internet, its just an intranet.
How to set up this please?
How many ISPs do you have and what is their throughput…
which 3 routers are you using.
what is the price of tea in china,
What is the airspeed velocity of an unladen swallow,
do you mean the european swallow or the african swallow…
Thanks for the reply.
3x RB951G running mipsbe and one dhcp each. No ISP. Just plain intranet. i just need my clients to get an ip and see each other. nothing more.
Since it is only “Intranet” you can deal with the failover/redudancy by using a larger scope and divide it across the 3
Eg. 172.16.0.0/16 , so this is a large IP-space, especially for only 300 devices.
On all 3 , the “network” would be 172.16.0.0/16 , but the differences will be in the ip-pools
Router 1 : Have it distribute 172.16.1.1 up to 172.16.2.254 , provide mask 255.255.0.0 and the gateway if needed ? (eg. gateway 172.16.0.1) and create such interface on your LAN
Router 2 : Have it distribute 172.16.3.1 up to 172.16.4.254 , provide mask 255.255.0.0
Router 3 : Have it distribute 172.16.5.1 up to 172.16.6.254 , provide mask 255.255.0.0
So, the client will cry for a dhcp-offer and the first to respond will make it happen, IF even 2 of your routers are “out”, 1 router still has a “pool” large enough to provide for 300 clients.
**Don’t worry about “load balancing” , 300 clients is … nothing …**if you would say I have 10.000 or 30.000 endpoint then you need to make some solid dhcp-architecture too.
They are all in 1 large IP-space so they can communicate with each other, and the DHCP-server does not matter.
Can you draw how these 300 clients are connected ? I mean, you must have various LAN-switches and somewhere these 3 RB915G’s must also be in that same IP-space.
As long as you provide a 255.255.0.0 “mask” to each client within that large 172.16.x.x “block” you are good.
I assume you do not have anything like VLAN’s ? Just 1 “flat” network ?
Hi. yes, its plain flat. the reason i am using 3x dhcp is frequent power cuts that can affect one or two routers…so at least one can serve the clients remaining.
Question: the clients will not need a gateway? if an assign one, and its the one going down what happens?
Thank you again for your time.
did you mean: each dhcp server provides it’s own gateway?
sure. no problem. each dhcp server in the same subnet needs separate block to offer, along with their specific setting. but unfortunately it doesn’t work smoothly on session based traffic.
you can specify as many gateway as you want in dhcp server gateway options settings for your clients use, but that method won’t work magically for any fail over for dhcp clients.
Ahhh..that is not going to work You cannot gain failover with regards to that aspect.
If you have 1 “flat” network why not look at VRRP ?
If you network is flat and you don’t have Internet … WHAT IS the gateway ? You need one ? Is any of these 3 routers a gateway to somewhere ??
No, dont tell me you need to see a network diagram and a better understanding of the requirements…
JV now fully engaged in playing whackamole LOL ( not even a full config seen yet )
If you only need to communicate among your 300 clients you do not need a gateway. Case closed and this solution will work.
If you have some requirement for some concept of gateway, please post a drawing because things can get more complex quickly.
