How to use API to /log warning "Testing Warnings"
I tried using this command in the API:
/log/warning
=message=“Testing Warnings”
but that doesn’t seem to work. Is anyone using the API to log?
Yes, the code works for me, though quotes are not necessary.
What client are you using?
