Hello ,
I’m trying to use this option - witout any success
I have created a simple html file and put it in the hotspot
now this are the setting I have use:(for some reason when I print user-profile I can’t see ahr advertise tab…)
advertise URL: test.html
advertise interval 00:01:00
advertise timeout: never
I have been waitng for 5 min never saw the test.html came
why ?
Thanks ,
Worked for me in the past, but then I dropped usage. As not a good solution for production. There are btter alternatives.
Anyway: You need to do active browsing. When the timer for advertisements expires, it will redirect you, when navifating to another URL.
Simple wait will not work
good to know , so why Mikrotik keep holding this option ?
what kind of alternatives do you recommand?
Thanks,
why Mikrotik keep holding this option<
Marketing argument. It works “in principal”. However, not good enough for production with many users, as number of complaints will increase.
Better alternative: I have a few, depending upon requirements.
However, I make my living from “good knowledge”.
In case, you are a WISP with serious interest in adverts on your hotspots, get in touch by email with my “pseudonym” augustus_meyerATyahoo.de
