Hello.
MT OS v.3.15. I try to write pearl script that will be change nat rule via ssh.
Question is: How can I find/delete specify rule?
For example:
[jaca@jaca] > /ip firewall nat print
0 ;;; blokada wisniewska
chain=dstnat action=dst-nat to-addresses=213.155.188.15 to-ports=82
protocol=tcp src-address=10.1.11.172 dst-port=0-65500
/ip firewall nat find src-address=10.1.11.172 - this command return empty result, why?
What i’m doing wrong? How to use find command to find and delete this rule?
Thank you.
Aug
2
[find]
usually used with another command like set
set [find dst-address=1.2.3.4] disabled=yes
Thanks man, it works!
[jaca@jaca] /ip firewall nat> print
chain=dstnat action=dst-nat to-addresses=213.155.188.10 to-ports=82
[jaca@jaca] /ip firewall nat> remove [find src-address=“10.1.11.172”]
You’re great!
