I’m quite new to RouteOS and need some advice on something I would like to do:
I just got a RB750 and would like to use it to wire a remote office that would receive internet via wi-fi.
I need to control each port differently for example: Port 1 would just be a bridge to the LAN, Port 2 would have an ip address 10.0.0.10, port3 10.0.0.11, port 4 10.0.0.12, and port 5 10.0.0.13…
Now, I don’t want ports 2-5 to be natted (I guess these will be networks), so pc connected to port 2-5 would not be bridged because I don’t want these to see the rest of the network. Now, I want to be able to see all ports from the rest of the network.
I need to control each IP separately since these have different access to places.
I have no idea if this is possible.
I’m a little confused on how to accomplish my task. Please guide me to where I can find how to do this.
Well, reading about PPPoE I noticed a PPP Server is needed. I already control ip addresses from a server I created running linux.
What I’m looking to do is install a Mikrotik switch on a building and assign each port an ip address that would be visible from the our LAN. Each apartment or client would have its own address that can be controlled (suspended or activated) from our server.
I have no idea how to do this other than just add a router to each client/apartment and have our client device in bridge mode. This is more expensive than just using a mikrotik to do the routing for each client/apartment.
you can configure RB750 as a PPPoE server then you can provide any IP Address to your client. Without PPPoE you can’t use like this or you can do subnetting.
