Hello, may i know if its possible to make the router to act as switch? what i mean by switch is as follow:
i have one ISP account
i have one cable from my ISP and its going directly to my Tenda11N router. it can only connect by providing the PPOE credentials other than that it cant connect.
i have recently registered for another account from the same ISP and they gave me different credentials.
so what i wanna do is:
insert the ISP cable into the mikrotik router via ether1
insert a cable on ether5 and connect it to my TendaN11 router
configure the mikrotik so that it can instantly forward all traffic into Tenda router so i can login from Tenda using one account and use the other account on my mikrotik (maybe using wireless)
It does work - read the manual. But as you are terse with detail (i.e. none at all), you can’t really expect any more help.
Post a config. export and don’t post stupid stuff like “it didn’t work”.
Edit: I see this guy takes out his ignorance by using negative ratings.
thanks for the reply, i’ve plugged in the ISP cable on ether1 and the tenda on ether5 ( i haven’t configured anything my self, all were default settings came with the mikrotik ).. tenda is still trying to connect (authenticating) but its taking forever.
i think its a firewall thing? maybe its authenticating but the ISP is blocking mikrotik’s MAC? how can i clone tenda’s MAC into ether1
