How to use traffic generator
hello
I’m trying to use mikrotik traffic generator to see the traffic between 2 units of mine
what do I need to config ? I have try some setting without any success
can some one show my a simple setting for testing 2 units ?
Unit1 - have a wireless+ether1 on a bridge - 10.0.0.1
Unit2 - have a wireless+ether1 on a bridge - 10.0.0.2
everything is connected , I have a normal ping of 20-40mSec
now how to I make the test ?
this is what I have done so far:
[admin@R1] > /tool traffic-generator packet-template
[admin@R1] /tool traffic-generator packet-template> add name=r12 head
er-stack=mac,ip,udp ip-gateway=172.16.10.51 ip-dst=172.16.10.50
[admin@R1] /tool traffic-generator packet-template> /
[admin@R1] /tool traffic-generator> quick tx-template=r12 packet-size
=60 mbps=1
SEQ    ID      TX-PACKET   TX-RATE     RX-PACKET   RX-RATE        RX-OOO
1      0           2 065 991.2kbps             0      0bps             0
2      0           2 084 1000.3...             0      0bps             0
3      0           2 083 999.8kbps             0      0bps             0
4      0           2 083 999.8kbps             0      0bps             0
5      0           2 084 1000.3...             0      0bps             0
6      0           2 082 999.3kbps             0      0bps             0
TOT    0          12 481 998.4kbps             0      0bps             0
but how do I know if this o.k.?
really I get no lost?
do I need to define anything on the second router?
Thanks ,
I think I make it work
but I get ~90% loss ? is it possible? is this something in the config maybe?
it doesn’t seem right,
 /tool traffic-generator quick
SEQ    ID      TX-PACKET   TX-RATE     RX-PACKET   RX-RATE        RX-OOO   LOST-PACKET LOST-RATE LAT-MIN LAT-AVG LAT-MAX JITTER
7      3           1 251 1000.8...            97  99.3kbps            46         1 154 901.4kbps 88.9ms  1.27s   4.19s   4.1s
8      3           1 250 1000.0...            99 101.3kbps            61         1 151 898.6kbps 84.6ms  703ms   1.47s   1.39s
9      3           1 239 991.2kbps           104 106.4kbps            61         1 135 884.7kbps 84.2ms  782ms   1.81s   1.73s
10     3           1 260 1008.0...            96  98.3kbps            54         1 164 909.6kbps 82.6ms  799ms   1.86s   1.78s
11     3           1 250 1000.0...           101 103.4kbps            69         1 149 896.5kbps 84.9ms  721ms   1.38s   1.29s
12     3           1 250 1000.0...           102 104.4kbps            61         1 148 895.5kbps 76ms    503ms   1.17s   1.09s
13     3           1 250 1000.0...           101 103.4kbps            62         1 149 896.5kbps 157ms   463ms   881ms   723ms
14     3           1 250 1000.0...            98 100.3kbps            51         1 152 899.6kbps 77.6ms  350ms   740ms   662ms
15     3           1 251 1000.8...           101 103.4kbps            58         1 150 897.3kbps 85.2ms  197ms   443ms   358ms
16     3           1 249 999.2kbps           100 102.4kbps            45         1 149 896.8kbps 73.2ms  155ms   278ms   205ms
17     3           1 231 984.8kbps           103 105.4kbps            45         1 128 879.3kbps 84.6ms  146ms   315ms   230ms
18     3           1 269 1015.2...            95  97.2kbps            46         1 174 917.9kbps 84.6ms  155ms   311ms   226ms
19     3           1 251 1000.8...           102 104.4kbps            46         1 149 896.3kbps 74.6ms  144ms   236ms   161ms
20     3           1 249 999.2kbps            98 100.3kbps            44         1 151 898.8kbps 74.8ms  126ms   219ms   144ms
21     3           1 251 1000.8...           102 104.4kbps            43         1 149 896.3kbps 74.8ms  124ms   242ms   167ms
22     3           1 249 999.2kbps           101 103.4kbps            48         1 148 895.7kbps 74.2ms  138ms   247ms   173ms
23     3           1 239 991.2kbps           107 109.5kbps            39         1 132 881.6kbps 74.2ms  114ms   181ms   107ms
24     3           1 261 1008.8...            92  94.2kbps            38         1 169 914.5kbps 75.3ms  122ms   225ms   149ms
25     3           1 250 1000.0...           100 102.4kbps            41         1 150 897.6kbps 72.6ms  118ms   195ms   123ms
TOT    3          31 240 999.6kbps         2 489 101.9kbps         1 257        28 751 897.7kbps 72.6ms  457ms   4.19s   4.11s
