I am using a Microtic Haplite router that a friend set up and it’s working fine.
I tried unsuccessfully to manually set up a repeater to extend the range. So I would like to try using the WPS button on my router and repeater.
Do I just need to briefly insert a pin in the WPS/reset feature of the router while it is turned on? I don’t wish to accidentally reset the router.
My other question, is WPS button enabled by default on this router? Your advice would be appreciated.
Kind regards
Chris
