How to using unset command throught RouterOS API
Dear All
I am using the API to develop an control software as ‘Mini-winbox’, now i face an trouble with the api.
when i want to issuse the command like ‘/ip/router/unset .id=*2 routing-mark’
,‘/ip/firewall/nat/unset .id=*24 src-address’ , i get get an argument error.
How to using unset command through RouterOS API?
Thank u very much~!
did sentence
/ip/router/unset
.id=*2
=routing-mark=
not work?
Dear Chupaka:
I am using the same command as below:
/ip/route/unset
=.id=*2
=routing-mark=
/ip/route/unset
=.id=*2
=routing-mark
but , doesn’t work, RouterOS replay
!trap
message=argument error
I am using RouterOS v3.0 or v3.9, has the same thing.
Would you like to test this? thanks you very much
hmmm… the same thing =)
Janis?
normis ? would you like to help us on this topic?
Anybody can help me on this? please~!
Also looking for this, after searching I found in another thread you have to use the value-name field.
So in this thread case that would be :
/ip/route/unset
=.id=*2
=value-name=routing-mark
A response 10 years late :slight_smile:
10 years later, and another 3 before I read it, but it still solved my problem today. Thank you forum!
