How to view/extract firewall logs?
Is it possible to view/extract the logs of the firewall?
EG: Any blocked traffic trying to come in/out at a certain time on a certain day?
Set up a firewall filter rule with the action of log, depending on your rules, probably place it before the drop rule. This will create an entry in your log under the firewall subject. If done improperly this will create a ton of log information.
