Good evening,
I configured OpenVPN on a Mikrotik HAP Lite, but I can't see the network names enough to connect to a specific computer via Remote Desktop. How can I fix this? Sorry, I'm using Google Translate.
If you mean DNS, you have to set the DNS Server in your OpenVPN Client Config.
Like so: “dhcp-option DNS”
For example, your DNS Server is at:
172.28.10.1
You can add the following line to your OpenVPN config:
dhcp-option DNS 172.28.10.1
otherwise, we need more details to help you
When your computer is not on the same network, you will not be able to “browse” to another computer in a list. You need to enter the name of the computer. It will probably remember it for a next time.
I tried to enter the computer name in the remote desktop connection but I can't access it
