each server has 2 lan cards, 1 int range, 1 ext range, im using a mirkotik CRS
we use to use bridges for each of the ranges and ports, but have since moved to using the SWITCH feature (master-slave ports) and its 10x quicker, and can handle more
however my vlans have stopped working?
i setup a vlan of 182 on the ext lan port on server and also create it on the mikroik too
but the ext lan port is set as masterport of our external ip range
is the way to bridge the 182 vlan on the ext lan port to a brigde thats setup on the mikrotik with an internal ip ?
hi,
tried a few things on that page and no luck,
when i try ‘set ether2 vlan-mode=secure vlan-header=always-strip default-vlan-id=200’
it just simply says ‘expected end of command’
it appears the is no vlan-mode and vlan-header, only vlan-type
i might have to keep looking
