Greetings from Wisconsin,
We need to rate limit outbound SSL connections to certain top level domains on an RB750Gr3. The subdomains change somewhat infrequently but frequent enough that maintaining an address list would prove laborsome. Is there a way to check the first connection made to “anysubdomain.anydomain.com” if it matches “.preferredtld.com”, such that I can add a packet mark, then put it into a simple queue? The last two steps I can handle, but how do I accomplish the first without spiking the CPU usage on the RB750Gr3?
Thank you in advance,
Isaac Grover
