How to Wireguard Back to a Specific VLAN Subnet?
I have VLANs setup, one is an admin VLAN. How do i set up wireguard so that I can connect to thr admin vlan?
By allowing WireGuard source IPs to the admin subnet and denying access to anything else for those source IPs in the firewall
When you say “source IPs”, is that in the Allowed Address in the Peer setup, or in the Client Address?
More likely firewall or service filtering based on the source subnet.
In my case, the VPN client device uses an IP adress from the same range as the wgX interface and that subnet is also named as the allowed adresses subnet if I remember correctly
The source IP filtering is done by firewall rules
