How to work 2 o more different Radius server for Mikrotik?
Hi
I want to configure 3 differents Radius for a same hotspot service in Mikrotik.
I added 3 differents Radius Servers for the same hotspot service in a Mikrotik, so, the users must be authenticated via Radius in hotspot profile.
But I dont know if this configuration is correct. If it is correct, please, could you tell me how it works?
Thanks in advanced
Alejandro
why?
RouterOS will not connect to the other RADIUS if the first one is reachable. So if your username is only on the second server, this will not work.
normis is correct about each domain radius server. They will not “fall through” unless the first does not respond.
I use multiple domains on a hotspot so I can use multiple radius servers. It requires different domains, so users would add a domain to the user name. I have the hotspot and radius sections set so something like these user names use different servers to authenticate:
myuser
myuser@domain1
myuser@domain2
Is that ok? Or are you expecting a fall through on Access-Reject?
