I have 20mbps bandwidth and want to work with static queues.
Now I have create static DHCP and what IP I set in my pc lan I get the full bandwidth(20MBPS). Than I create simple queue and set speed on each and every IP but when I put different IP which is not create in Queue I get full speed. Now I want to know is it possible that what IP I create in queue only it should work other IP should be blocked. for Example
DHCP IP Pool;- 10.10.0.2-10.10.0.255
Queue IP pool:- 10.10.0.2-10.10.0.50
Other Ip 10.10.0.51-255 should be blocked.
I don’t know how to do. I will be very thankful for your support.
