How use GPRS Modem in Router Board 532
Can anybody help me, how to install /use GPRS Modem in routerboard ?
How about GSM/GPRS miniPCI …?.. :laughing:
Routerboard 230
only RB 230 ?
any other ?..
what gprs modem supported rb230?
all GPRS modems that I have seen - they are PCMCIA card. The only RouterBOARD that has a PCMCIA slot is the RB230. First, tell us what model of GPRS modem you want to use
Yes, but there are some model which you have never seen… :wink:
I have a Fujitsu Siemens Connect2Air Compact Flash Card, GSM/GPRS. Is it supported by RB153 or RB532?
if it’s not in the driver list - no
http://www.mikrotik.com/testdocs/ros/2.9/guide/driverlist.php
also - RouterBOARDs support only CF in the CF slot.
please, tell me, what’s CF can be use ?
NONE. RB230 or NOTHING. Can’t think of any other way to say it.
