how vodafone K4305 3g modem setup
I have connect the vodafone K4305 3g modem to my rb 751G-2Hnd
The led are blinking green.
If i look to system, recources, usb see a the modem but no port
By interfaces see i LTE1
How must i configure the 3g modem
What must i full in by the latest picture?
Must i configure ppp-client?
Put you pin if you have pin anabled, and Your apn from provider. Then user/pass if the provider use this. (probobly not)
Tnx for reply
What is APN ?
And for config PPP see a not a port (example usb2)
I have and see no ports i think there is a problem
See log file
I missing a port Or is this modem not compatible with mikrotik routers
Mikrotik crew help me pleace
Topic is resolved.
3G modem comes as an interface that you need to set with a DHCP client.
The Vodafone K4305 is compatible with Mikrotik Routerboarden.
