What would be the easiest way to configure a set of machine to only send and receive data from one WAN?
I have actually 2 wan with a physical port on a CRS2004 and wanted to be able to route all the incoming/traffic to one particular WAN for TVs and other entertainment device. Unfortunately I can’t limit them to only one VLAN for now since this would imply to configure a RADIUS server. Machines can receive a static IP in their network.
hello benoitc,
it’s a bit tricky config but maybe you might want to try it?
https://wiki.mikrotik.com/wiki/Manual:PCC
hope this helps
Is’nt it possible to … just an idea:
- set address list of selected devices.
- do set filter rule which drobs traffic sourced from that list if it is send to eg. WAN1
- allow traffic do WAN2 for them
- set NAT rule with source address list to src-nat to WAN1 address instead of masquarade
- put rule from (4) before masquarade.
