hi
Can anyone trying to solve my problem?
Tkanks!!!
Just connect it to the device using a CAT5 cable.
I’d give up the networking job and concentrate on your budding career as a top class technical document specialist, as the problem was laid out so well and made it so easy for us to understand your problem and provide you with help.
i was thinking he’s asking for how to connect airmax enabled devices to mikrotik’s nv2/nstreme wireless
If the ap is using proprietary protocols then you can’t. Simple
Tis is unpassible.
Airmax en Nv2 works not together
Tis is impossible.
