howto get Caller ID from l2tp-server- binding conection
I have two mikrotika.
One has a static address, and other dynamically.
between them is the L2TP tunnel.
the Mikrotik static address to see CallerID second mikrotika but I can not pull out the script.
/ ppp active print
Flags: R - radius
NAME SERVICE CALLER-ID ADDRESS UPTIME ENCODING
0 name l2tp a.b.c.d 10.0.1.1 3m33s MPPE128 stateless
How to extract caller ID and put it to firewall rule?
For do what?
On Filter?
On NAT?
On Mangle?
To obtain the value:
:put [/ppp active get value-name=caller-id [find where name=> connection-name > ]]
the idea is to get out the current public address Mikrotik (which has no static) to be implemented in the firewall rule.
Thank you for your fast response
