howto import batch of users
  1. May you send me 1 line command line (for terminal) to create user to user manager with following characteric: username, password, customer, profile and activate
  2. howto import batch of users (say 50 at a time in CSV file) to mikrotik user manager? step by step instruction will help.
    thanks
I am having the same problem
I need to import all the hotspot users into user manager
I copied all the users from the spot to my desktop
in rsc file..but i dont know how to upload to user manager
please help
Hi
this is very easy
/tool user-manager user
add customer=YOUR-CUSTOMER-NAME name=USER-NAME password=PASSWORD-FOR-USER
fill:
YOUR-CUSTOMER-NAME with customer created in UM
==>But you can't assign a profile for created user,must manually do it.
if your user are too much,you can use "Mouse and Keyboard Recorder".
Mouse and Keyboard Recorder is a tiny program for recording your mouse activity and do it several time automaticly.
Instead of hijacking this thread, which is a tutorial, try creating a new thread with your problem. Also, don’t expect much help from others unless you provide much more detail about your problem than you gave here (which was for all purposes none).
