Howto join several VLANs on a Bridge?
With a switch with statically configured VLANs, I am trying to achieve a double scenario:
  • one for routing the ports
  • other making it appear as switching among them (see the images).
The fact is that when I add a second VLAN to the bridge the MT stops replying to the ARP requests.
There is a way of doing this?
Config for routing scenario:
add name=br-Switching
add name=br-Vlan4
add name=br-Vlan5
/interface vlan
add interface=ether1 name=vlan4 vlan-id=4
add interface=ether1 name=vlan5 vlan-id=5
add interface=ether1 name=vlan10 vlan-id=10
add bridge=br-Switching interface=vlan10
add bridge=br-Vlan4 interface=vlan4
add bridge=br-Vlan5 interface=vlan5
add address=192.168.2.2/24 interface=br-Switching network=192.168.2.0
add address=192.169.0.1/24 interface=ether2 network=192.169.0.0
add address=192.169.200.1/24 interface=ether3 network=192.169.200.0
add address=192.168.4.2/24 interface=br-Vlan4 network=192.168.4.0
add address=192.168.5.2/24 interface=br-Vlan5 network=192.168.5.0
Config for switching scenario:
add name=br-Vlan4
add name=br-Vlan5
/interface vlan
add bridge=br-Switching interface=vlan4
add bridge=br-Switching interface=vlan5
Thanks.
First off I’m going to make some presumptions about your environment since you haven’t specified model numbers or OS versions. Your diagram #2 shows some weird addressing, that doesn’t match with the config given, again I’ll presume it’s a typo.
When attempting to do what you want from a router, bridging VLAN’s together is a bit different when you want to trunk them. There’s no need on the router to use the bridge for just trunking unless you have spanning tree requirements or other layer 2 needs. The switch will handle the trunk and all the “magic” happens there. All of this is only good for ROS 6.40.X, in the next ROS there are MAJOR changes to this functionality and will require using bridging on the switch. If you are currently using bridging on the switch for this, you will be using the switch CPU INSTEAD of the switching chip, which is faster and designed to work with VLAN trunks. See this wiki for more info: https://wiki.mikrotik.com/wiki/Manual:CRS_examples
In the current stable ROS 6.40.x, to accomplish what you want create your VLAN’s on their interfaces this will form your “TRUNK” on ether1 of your router.
Note: that if your main interface has no addressing on it the default VLAN 1 is still part of the trunk, there is just no layer 3 config for it.
If you are planning on managing the switch “in-band” then you’ll need to untag one of your trunk VLANs on the switch so it can get an ip address.
/interface vlan
Add your addressing on those VLAN’s
add address=192.168.2.2/24 interface=vlan10 network=192.168.2.0
add address=192.168.4.2/24 interface=vlan4 network=192.168.4.0
add address=192.168.5.2/24 interface=vlan5 network=192.168.5.0
Do any additional routing / NATing etc.
Plug ether1 into your switch, I never use the master port as an uplink port for various reasons, that choice is up to you.
If your switch is at default configuration then the master port is ether1, regardless which ever port you plug the router into will be your “egress port” for VLAN switching.
Time for the switch to do it’s magic. (BTW, there is not port 0 (zero) so I’m using port 2 for vlan 4)
First create the vlan’s with their port assignments, on the port you plugged the router into (let’s just say it was port 24) and all the access ports you will have in that vlan on the switch.
add ports=ether24,ether2 vlan-id=4 learn=yes
add ports=ether24,ether4 vlan-id=10 learn=yes
add ports=ether24,ether5 vlan-id=5 learn=yes
Now create the “access” ports where your devices will plug into.
/interface ethernet switch ingress-vlan-translation
add ports=ether2 customer-vid=0 new-customer-vid=4 sa-learning=yes
add ports=ether4 customer-vid=0 new-customer-vid=10 sa-learning=yes
add ports=ether5 customer-vid=0 new-customer-vid=5 sa-learning=yes
Now you need to configure the egress tagging on the port you plugged the router into. (let’s just say it was port 24)
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether24 vlan-id=4
add tagged-ports=ether24 vlan-id=5
add tagged-ports=ether24 vlan-id=10
This configuration is a standard build for access ports on a switch.
For managing the switch in-band: (I’m not sure which VLAN you want to use for the, let’s just say 4 and you can change it later)
The simplest thing to do is create a VLAN on the switch that the SWOS/ROS will use for management, on the MASTER port!
Again, I’m presuming a default config here, change if required.
/interface vlan
add interface=ether1-master name=equipment-vlan vlan-id=4
If you’re using DHCP then:
/ip dhcp-client
add disabled=no interface=equipment-vlan
If you’re using static addresses then
add address=192.168.2.x/24 interface=equipment-vlan network=192.168.2.0
I hope this helps you out.
Cheers,
Icosa
Icosa,
Thanks for your replay.
Unfortunately the “statically configured switch” is an IC-Plus IP178C integrated circuit. For this switch we have very limited information and so I only managed to make it tagging VLANs packages. I know it will not be efficient but I would prefer to solve the problem on the router because I thought is would be easier.
Anyway I am still digging on the original solution. Looking at Wireshark captures I have the feeling that the RB, when answering, is not tagging the packets. I thought is was only need to create the VLANs attached to the trunk physical port and the bridge (to have some traffic flowing through it). Is there any specific detail to be aware on this type of configuration?
P.S. Hope I managed to attach one of the .pcap files to this post just in case you want to look at it.
I see here http://www.icplus.com.tw/pp-IP178C.html that it supports VLAN’s to some degree.
“Support port base VLAN & tag VLAN”
You problem will be if you want different ports on the switch to access different VLANs on the router you HAVE to untag them on the switch if the device is NOT capable of VLAN tagging in its own Ethernet interface. This is a basic layer 2 requirement, no amount of fancy bridge work will accomplish this.
Since the switch in question seems to support VLAN tagging it may be a good idea to contact the manufacturer and ask how to do VLAN access ports on their device.
Icosa
At the moment I am able to make the scenarios work using a RB and a TP-LINK switch.
Anyway there are a couple of things I do not know about VLANs which are:
  • Is the ARP request tagged and the reply too?
  • The MAC address shall be the same of the physical port or not?
  • If we have a VLAN on a bridge, having assigned to it an IP address, the MAC is always the same (for VLAN, bridge and physical port)?
Shall I start a new topic to see if anyone ca explain this to me?
Thanks.
Icosa.
