HowTo Seperate users in a multiple hotspots+single Userman
Hi guys
I have my MK running fine with four network cards and three hotspot servers running on three of the interfaces.
Once I create a user in the userman, the user can login on any of the hotspots.
Now, I want to seperate my hotspot users such that users on hotspot(1) will not be able to login on hotspot(2).
Please how can i do this with Usermanager.
Thankx in adv
Yes.. This is very big problem..
Currently you need to have different customers [User Manager administrators].
One customer with routers and users.
Second customer with other router and users.
User belonging to customer one is not able to login into second customer routers.
Thankx sergejs
I’ve tried it but it seems customers cannot be attached to a particular router only Subcriber can do such.
Let me try it with subscribers and give you back the feedback.
Thankx so much for the light
You really made my day.
I’ve created another subcriber and added routers but I’m mot sure of what to do with \router
I’m totaly confused.
I have assigned diffrent IP’s to my Hotspot servers and also created routers in each of hem to handle each hotspot server but all I get is “Radius server not responding”
Each customers owns separate settings.
One customer has its own routers users, the same is for the second customer.
Please, check your configuration for RADIUS client and make sure all IP addresses are correct.
i am having the same issue with V7 did anyone find a solution?
