Howto setup PCC with Netwatch ??
I am using mikrotik pcc to load balance 4 dsl links.
My problem is that sometimes ONE or TWO DSL Links face internet connectivity problem from the ISP end, but the PCC script will always tell the pcc that the gateway is ok by using check-gateway=ping which always check the local dsl router gateway.
Is it possible with Mikrotik to load balancing using PCC , and fail over but checking not the gateway, but other IP like google or yahoo. To be sure that there’s reach-ability after the gateway. Because the gateway can be reachable and that gateway itself don’t have reach-ability and checking the gateway will always tell you that all is ok.
Howto integrate it with pcc script ?
add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=Local
add address=192.168.1.2/24 network=192.168.1.0 broadcast=192.168.1.255 interface=WAN1
add address=192.168.2.2/24 network=192.168.2.0 broadcast=192.168.2.255 interface=WAN2
add address=192.168.3.2/24 network=192.168.3.0 broadcast=192.168.3.255 interface=WAN3
add address=192.168.4.2/24 network=192.168.4.0 broadcast=192.168.4.255 interface=WAN4
/ip firewall mangle
add chain=input in-interface=WAN1 action=mark-connection new-connection-mark=WAN1_conn
add chain=input in-interface=WAN2 action=mark-connection new-connection-mark=WAN2_conn
add chain=input in-interface=WAN3 action=mark-connection new-connection-mark=WAN3_conn
add chain=input in-interface=WAN4 action=mark-connection new-connection-mark=WAN4_conn
add chain=output connection-mark=WAN1_conn action=mark-routing new-routing-mark=to_WAN1
add chain=output connection-mark=WAN2_conn action=mark-routing new-routing-mark=to_WAN2
add chain=output connection-mark=WAN3_conn action=mark-routing new-routing-mark=to_WAN3
add chain=output connection-mark=WAN4_conn action=mark-routing new-routing-mark=to_WAN4
add chain=prerouting dst-address=192.168.1.0/24 action=accept in-interface=Local
add chain=prerouting dst-address=192.168.2.0/24 action=accept in-interface=Local
add chain=prerouting dst-address=192.168.3.0/24 action=accept in-interface=Local
add chain=prerouting dst-address=192.168.4.0/24 action=accept in-interface=Local
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=src-address:4/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=src-address:4/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=src-address:4/2 action=mark-connection new-connection-mark=WAN3_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=src-address:4/3 action=mark-connection new-connection-mark=WAN4_conn passthrough=yes
add chain=prerouting connection-mark=WAN1_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting connection-mark=WAN3_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN3
add chain=prerouting connection-mark=WAN4_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN4
add dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=to_WAN1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-mark=to_WAN2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.3.1 routing-mark=to_WAN3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.4.1 routing-mark=to_WAN4 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.1.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 distance=2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.3.1 distance=3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.4.1 distance=4 check-gateway=ping
add chain=srcnat out-interface=WAN1 action=masquerade
add chain=srcnat out-interface=WAN2 action=masquerade
add chain=srcnat out-interface=WAN3 action=masquerade
add chain=srcnat out-interface=WAN4 action=masquerade
With some clever use of the routing table, you can effectively make check-gateway use external servers instead of just the gateway.
http://wiki.mikrotik.com/wiki/Advanced_Routing_Failover_without_Scripting
