Hi
how can I set up static subnet prefixes for connected interfaces from a provider DHCPv6 assigned IPv6 pool with RouterOS?
Using this configuration does not work on RouterOS:
[admin@mikrotik-labdemo] /ipv6 pool> print
Flags: D - dynamic
# NAME PREFIX PREFIX-LENGTH EXPIRES-AFTER
0 D DSL-IPV6-POOL 2001:beef:cafe:ff00::/56 64 1h46m45s
[admin@mikrotik-labdemo] /ipv6 pool> /ipv6 address
[admin@mikrotik-labdemo] /ipv6 address> export
add address=::a:0:0:0:feed from-pool=DSL-IPV6-POOL interface=vlan10
add address=::b:0:0:0:feed from-pool=DSL-IPV6-POOL interface=vlan11
add address=::c:0:0:0:feed from-pool=DSL-IPV6-POOL interface=vlan12
RouterOS is ignoring the subnet prefix part which results in random (up counting) subnet assignments from the ipv6 pool.
Using the same configuration with Cisco IOS works perfectly fine:
interface Dialer0
description DSL
ipv6 enable
no ipv6 redirects
no ipv6 unreachables
ipv6 verify unicast reverse-path
ipv6 dhcp client pd DSL-IPV6-POOL rapid-commit
interface Vlan10
ip address ...
ipv6 address DSL-IPV6-POOL ::A:0:0:0:FEED/64
interface Vlan11
ip address ...
ipv6 address DSL-IPV6-POOL ::B:0:0:0:FEED/64
interface Vlan12
ip address ...
ipv6 address DSL-IPV6-POOL ::C:0:0:0:FEED/64
Any hints on how to fix this issue on Mikrotik RouterOS?
-fflo
