I have 2 RB532’s running firewall NATD and Source NAT with no problems.
The 2 routers are performing flawlessly so far at each end. The next phase is to link the 2 together as a VPN.
Location 1, has 192.168.0.0/24 network. SCO unix server, FreeBSD mail server etc.
Location 2 has 192.168.3.0/24 netblock. No servers.
I have built a l2tp tunnel successfully, I can telnet to addresses on both networks, use a terminal emulation in the port 7xxx range, use winbox on the other network etc.. everything works except printing to HP jetdirect servers.
PPTP directly from a windows machine does not work either..
HP jetdirect uses port 9100 some web resources suggested making sure port 161 SNMP is open. However I can portscan the remote printers and see them on port 161 so its open.
The printers do have the gateway address set to the rb532.
Idea’s??
Jerry
