Can someone tell me if it’s possible for mikrotik to run on HP PROLIANT DL360 G4 which is using SCSI HDD?
If the answer is yes, is there any particular method to follow?
Best regards
Best regards
RouterOS doesn’t support SCSI. You need IDE or SATA storage
thanks a lot normis
USB work nice on this servers
