If this is set to “auto”; how, or when, is ROS going for ‘long’ or the ‘short’ interval?
I noticed that on some links manually setting to “long” drastically improved my CCQ on bad links. (at the cost of connection rate and thus raw throughput).
Should “any” not be “auto” as in “ROS decides”? And if so, how is it then decided what to set it for?
Anybody with any insight?
