HTML form inside mikrotik
Hello!
I want to create an HMTL page inside mikrotik (for example, creating setup.html and uploading to the router by ftp), which can be accessible for example at 192.168.1.10/setup.html. The problem is that I want this page to be a form, and the values entered in this form should be available later with mikrotik scripting language. For example, writing the values entered in the form into a txt file and read this txt, and then read the txt file with an script.
Does anyone if it is posible?
Thank you!
This is not possible using the router alone. It can be done using an external web server + php api
