Http Freeze and slow Internet because of WebProxy
Dear all,
I try to block websites with path via webproxy(Ex:website.com/something.php).
I can block website (Ex:website.com/something.php) by Web Proxy.
The main problem. When I use redirect in firewall nat, my Internet speed goes down, and website blocking works.I spend more time to fix this problem but I couldnt find anything to fix.
My rules are these, thanks for advices
ip proxy print
enabled: yes
src-address: ::
port: 32702
anonymous: no
parent-proxy: 0.0.0.0
parent-proxy-port: 0
cache-administrator: webmaster
max-cache-size: 2000000000KiB
max-cache-object-size: 2048KiB
cache-on-disk: yes
max-client-connections: 600
max-server-connections: 600
max-fresh-time: 3d
serialize-connections: no
always-from-cache: yes
cache-hit-dscp: 4
cache-path: web-proxy1
ip firewall nat
ip firewall nat add chain=dstnat src-address=192.168.100.123 protocol=tcp dst-port=80 action=redirect to-ports=32702
ip proxy access
—addded blocked websites.
how are you testing the browsing speed?
any processing that you do, will reduce the speed somewhat. the question is, by how much
Thanks to reply,
When Iam browsing page comes late like 5seconds or 7seconds. THe problem doesnt appear only for me. more than 100 user says same thing. But when I disable redirect rule everything comes ok
hello
how you fix this problem? i`m new at mikrotik, can you write step-by step :slight_smile: thx
Adding too much firewall rules and blocking not only might make a speed decrease but also will exhaust the cpu of routerboard,“ofcourse it depneds on the RouterBoard you use”.i Suggest installing a firewall appliance or pfsense server and block what you want and keep RouterBoard working with its full power.
Now how you can achive that?
if your newbie suggest requesting such service from experienced Mikrotik
