HTTP PAGE
hello everybody..i have a question
when i go in http page of my router ip address, can anybody tell me how can i make it with user and password..
i know the way how to disable this port, but i dont wanna disable it just to make it with user and password to have access in it..
THankYOu
it’s the same as ur MT box user and password default is “admin” with blank pass.
best regards
i dont know if you understand me..i mean how can i make this page with user and password access, because the clients can access on it without problem..and i dont wanna disable 80 port, but i wanna make this page with password access..
Respectt
It is not possible to make this page with username and password.
So the way is,
or you may use firewall and drop specific IP addresses or allow access only to specific IP addresses.
can you tell me the firewall filter how to drop specific ip addressess or allow only an ip address.
P.S its any firewall filter to drop pinging for specific addressess to, and allow only an ip addres to ping the router..
Or you can change the default port 80 to another port like 82 then your user can’t get that web page cause they’ll not know your new port. you can do it from IP>services> www and change your defaullt www port to 82.
After you log in. Go to system on the left and click the Change password link. Or, serial/telnet/ssh into the router and type /password and press enter.
Not sure if this will wrk for you, but I am pretty sure it is what you are looking for.
Cory
but if i change the port number how can i access in http page of my router ip..
After changing your default port you have to use the new port like this> (IP address of your router:82) (x.x.x.x:82)
Do I make myself clear?
Yes you did youreself clear..
ThankYou very much it worked well..
